Hello
Can someone please help
My wife's 2004 Micra k12 driver's side headlight (dipped) does not work...The passage Headlight works and both side lights work...also when I switch the full beam on both sides work...so quite literally the driverside headlight is the only one that doesn't work....
I've swapped the bulb and no joy...ive swapped the 3 pin connecter that plugs into the bulb and no joy either...
I've looked for the fuse but can only find a yellow block fuse which says h/lamp and washer but like I say everything else works inc the washer so surely can't be the fuse...
So I've only got the option of following the wiring and checking to see if I find a fault on the wire and that's it really...I'm losing my mind over this
Can anyone help...Thanks in advance
