CMF_micrafun2
» CMF MemberI have now replaced my first CV joint onto a drive shaft.
Woot! Woot!
This is quite advanced work for me!!
I am about to put back the passenger side drive shaft.
I cannot clearly see into the gear box.
Is there normally an oil seal there?
If so, I am not thinking of replacing it.
What do people think?
Is it recommended to replace it to avoid losing gearbox oil?
Asdame, if you are looking at this post, pls give me an indication on torque setting for the drive shaft main nut -which is the first one you remove to get the whole thing started off.
Also the supplied nut feels quite stiff to fit on to the drive shaft. Is this normal? Is it like the crank shaft pulley bolt - is it what some people call a pinch bolt?
Danny
Woot! Woot!
Danny
