Last few weeks I have noticed that the drivers door does not unlock/open after sitting over night with freezing temps either using the external or internal handle. All 3 other doors are fine and open no problem, just the drivers side. Using the key makes no difference.
I have applied white grease and sprayed a liberal amount of W40 around the door catch area, however it was still problematic this morning.
Once open (usually by repeat unlocking/locking), its fine and the problem does not come back until sat over night again with freezing temperatures.
Although this morning I got it open prior to my Mrs going out, however 30 minutes later she complained that she could not get in. A couple of lock/unlocks it opened and again was fine for the rest of the day.
Anybody else experience this? Is this a sign that the door catch/lock mech is failing and I should consider replacing before it gets worse and prevents the door opening at all? Or is there any further service I can do such as lubricating anything else?
