M micramac Deactivated Account Apr 2, 2008 #1 how do i remove the top part of the door card? the part that is plastic and attached to the bottom part of the window? my car is a K11
Retepetsir King of Subsonic Apr 2, 2008 #2 You have to unpop the door card along the bottom and sides, then pull the doorcard away at an angle from the bottom and with the window up it should lift off at the top. Basically you need to pull it out then push it upwards!
