door and rear speakers
wait.... 7" speakers in the front? wft that is a weird size. on the australia micra forums, it appears 6" speakers will fit in the spot but may be too deep unless you remove the grille & mount them to the outside of the door card using the aftermarket grille,
OK I replaced all my speakers yesterday. 6.5" will fit perfectly all round. I think mounting depth may be an issue with something like a 3 way that have deep base in the front. I put 6x9 in the rear all I did was remove the black mounting thing and then made new holes to screw straight into the factory grille. Parcel shelf needed to be cut to fit or you may get away with 10mm spacers
Sent From Hell Using Tapatalk 2..... Biaaatch!
