Doesen't start
Hi, time ago a truck crush in to my car and i had to replace the rear axle, since this happen my micra wasn't anymore like before, if i was starting the car after few day's was starting and cangarooing spitting water from the exhaust, i then decide to give a good check arround, dizzy cap cleaned, spark plug ok, sparks coming, then took TB cleaned, done resoldering trick, cleaned injectors, charge battery, today put in self diagnosis mode, code 55 came so all good, but the car doesn't want to start.
Car is a GX auto, 1.3.
Any idea will be appreciated.
Hi guys, well tryed again to start the car and looks like is goin to start and then making like a pop noise and little smoke is coming up from TB.
This are the spark plugs from this morning, put new set on but nothing.
Finally today i start the car, was flooded and a bit ard but at the end the engine is singing again, now i have to replace temperature sensor as is overfuelling.
Thanks everyone.
Write your reply...
