Hello;
For the past couple of weeks has had slow running wipers, dim headlights/dashboard,
and rough idling. Sometimes when idling the battery light comes on. These do not all occur all the time, sometimes just one or two of the faults occur. Occasionally none occur. Other times the battery light can stay on for a while when driving and go off suddenly. I have had the car looked at twice. First time was told battery was shorting inside and was replaced. still the fault occured. So i took it back and had it tested again. This time the wires and connections to the alternator were checked and cleaned. both times the alt was tested and no fault could be found with it. could something else cause these problems or is it the alternator as i think. I was quoted £320 to replace so i hope for another fault.:down:
