D
Deleted member 29304
Hi All,
I was just thinking does anyone know if the K11 micras have fuel injectors because if they do it is advisable to keep them clean via adding an addtive to the fuel tank every (3000 miles as it says on the bottle of STP injector cleaner )to keep them clean and to prevent any MOT failure the injector cleaner will not effect the CAT's and it will cut out any big bills. Even if your are using premeuim fuel which has cleaning agents in I can't afford that stuff so I have beeen using the standard unleaded and have added the additive anyway.
Yours Peter Rowley
Yours Peter Rowley
