W
W4SIM
Hello all
Please try and bear with me on this if you can.
In a recent thread i asked how the battery was supposed to be tied down as mine was loose and kept moving onto the clutch cable adjuster bit.
Well i sorted the battery out, sprayed some WD40 on the moving parts of the clutch itself as i could see some rust and then just left it.
Took the car to work about an hour or two later and thats where the problems started. At first it was jerking under accelration throughout all gears, but then that sorted itself out when the car warmed up.
The next day it had trouble starting up, this has ALWAYS been a first time starter since iv had it for about 5months, this is the 1st time it had starting issues. That was yesterday. Then after work it wouldnt start and started on about the 4th attempt. And now today it wont start at all, even on about the 5th attempt.
Iv checked the sparks and made sure theres anough fuel in there but nothing. Its kinda like getting there but not quite ticking over if you know what i mean, its JUSt falling short of actually turning over. It has been raining since that day but rain has never ever caused a starting problem before so im completely baffled by this.
So has any 1 got any ideas? Could a quick spray of WD40 have really done this? Or is there something else thats abit more common that im missing?
Your help would be much appreciated.
Thanks.
Thanks.
