DJ CD Decks & Mixer
scottish-sr
I am putting a feeler out to see if anyone is interested in my CD Deck & Mixer Setup.
1* Gemini CFX 30 CD Deck.
* Audio CD, CD-R, & CD-RW compatible
* 8 DSP effects: Filter, Zoom, Echo, Pan, Reverse, Trans, Brake & Scratch
* Precise Dry/Wet FX parameter, start & brake rotary controls
* 5 Fly cues & 4 sampler memory buttons
* Easy to operate memo button for cue function & sampling
* Vinyl/CD jog mode function
* Master cue has hot-start feature
* +10 track selection knob
* Key lock & BPM controls
* Anti-shock using RAM buffer memory
* Slot in mechanism with blue LED display
* Fully programmable direct access keypad
* Single auto-cue/continuous play mode
* Seamless looping with reloop/stutter & loop editing
* Pitch bend via jog wheel or buttons
* Three mode time selection
* Frame accurate search & cue
* Large blue backlit LCD display w/ dimmer control
* Coaxial RCA digital output
* Rubber jog wheel with finger grooves
* Variable pitch control with ranges of 4%, 8% , 16%, 100%
* Soft touch buttons with bright LEDs
1* Stanton S-250 CD Deck
# Top-loading single CD player designed for professional DJ performance
# Instant and fader starts; selectable pitch range of +/- 8, 12, and 16 percent
# Control panel and LED screen located toward front of unit for easy access
# Displays elapsed and remaining time in minutes and seconds
1* Gemini PS626 Mixer
3 Channels
Gain Controls
3 Band EQ
Mic
The CFX30 was £250 new, Stanton £120 and the Mixer £120.
The 2 CD players have boxes and instructions, the mixer doesn't
All works perfect, a great setup for someone wanting to take up DJing or for DJ wanting to move over to CD's
I will get actual pictures of the decks if anyone is interested. Looking for £300 ono. Will post at buyers expense.
