CMF_Lx_Micra
» CMF Memberhey guys
I changed distributor a little while back bought a second hand one from the wreckers $80. I installed it works well the only issue is that ever since then ive been doing 360km on a 35liters whereas before i was doing about 400km on 35 liters. So i asked around at work today for a timing light and the guys gona bring it in for me tomorrow. Now how do i set the timing what am i looking for. i know i have to loosen the distributor and rotate to align the timing.
So can anyone run me through the steps.
how can i get my Fuel economy higher, these are the things ive done
Resolder the throttle body
check the pot on the throttle and adjust to 5kohm from memory
bought new K and N standard Air Filter
Bought an NGK oxygen sensor
pumped up the tires 14 inch to 32 psi
things i havent done
adjust the distributor timing
cold air intake.
check the temperature sensor (any pics of it)(What resistance and at what temperatures am i looking for)
What distance are ppl traveling in there micras Quote KM and Liters please so i can compare.
cold air intake.
