dipped headlights fuse
Hi Guys!
My both dipped headlights don't work !!! i suppose ther irs a problem with a fuse!! but i can't find the right fuse!!! i'm italian and i have some problem with the name of fuses! can anyone help me?!?
the name of fuses are:
DTRL
ALT S
HORN
EPS
H/LAMP WASHER
ABS
P/WDW BCM
DTRL RLY
PTC/ROOF
IGN SW
RAD FAN
ABS
ROOF
thanx guys i'm waiting your answer
Dip/Low Beam Headlamps Failure
This is a common repeat failure on the K 12 Micra that invariably relates to the computer can bus datacoms controlled area network input/output interfaces hardware modules communications failures;~ not the fuses which are separate for the left-hand and right-hand low beam headlamps.
May I refer you to my earlier work on this as follows?
Reference; https://www.micra.org.uk/threads/k12-fuse-box-under-headlight.66107/
Warning. Do not disconnect and reconnect the battery and do not attempt to interchange the modules as this can introduce multiple failures in the can bus datacoms system! Only the relays are interchangeable without recalibration reprogramming using specialist equipment and expert automotive auto electronics technician services.
Hope this helps with a logical fault finding sequence.
