karlj Mar 2, 2013 #1 Does anyone know how to remove a stuck dip stick, need to remove Charlie's but the plastic handle has completely broke. There is a little tab of metal that I've tried gripping with mole grips but that's not worked
Belly93 to turbo or new lump :/ hmmm Mar 2, 2013 #2 Apart from removing the sump and; pushing it out not sure
OP OP karlj Mar 2, 2013 #4 frank said: the outer tube comes out pretty easy karl Click to expand... Is it just a push fit?
OP OP karlj Mar 2, 2013 #6 In that case I'll see if I can get it removed tomorrow. Just so I can prepare my knuckles it's just a case of wiggle and pull until it pops out and I go flying
Wagoneer Mar 6, 2013 #7 I expect a few squirts of lubricating oil around the point where it goes into the block might be useful too.
