Long story short: If you get your belts done due to any noise, have the mechanic check the main serpentine and supercharger tensioner 2 and 4 in the image below), rather than just doing the belts! It seems both are Nissan only parts and hellishly expensive to replace!
For the last 18-24 months, the serpentine belt (as advised by a garage) has been making a noise when cold, but would clear up after being driven. IT is more obvious when its been over night and in damp conditions.
However, today I noticed that the noise has changed to more of a, well, the only way I can describe it is it sounds a bit like a rattle can type noise. Probably the bearings.
Inspecting the engine, it sounds like its coming from the mid to rear side of the engine. In the image below taken from the Nissan workshop manual, it sounds like No 3 - super charger clutch, but I suppose it could be No 4 (this is preferred, as I dare say a simple idle pulley is far cheaper than a electro-mag clutch!)
I do note that the noise does not depend or change on supercharger operation, (so rules out 1 and 2) so it suggests pulley 4...
Car has done just shy of 67k and is approx 8 years old so probably due a change.
Not really the weather to go pulling the inner arch out so further research is needed! Over to the Note owners club forum I go!
