Hi, you can fit an earlier non-nats ecu, swap around a few wires and you're done. Most of the people in this forum refer to Ed from fusion motorsports for a solution, but Ed his info is no longer online, his micra links on his website are dead and he doesn't respond to emails. I've spent some time trying to fix this exact same issue, and have fixed it 100%.
This "fix" is for the micra with the key with the red chip in it, and the non-coilpack engine with the single distributor.
Get an early ecu (the oblong one, not a square one) that fits your engine (either cg10 or cg13).
On the engine loom (so on the plug to the ecu) switch over these wires:
switch pin 106 to pin 104
switch pin 12 to pin 36
switch pin 31 to pin 22
switch pin 40 to pin 30
After this your car will not have an immobiliser anymore but you can still use your old keys.
you can send some thanks to https://www.paypal.com/paypalme/willemjacobdijkstra => I've spent considerable time on this, but would like to share the knowledge (unlike some!)
P.S.
If you have an australian car, you can just plug in a non-immobilised ecu and it will just work!
P.S.
