if you wanna secure it stick a bit of sikoflex on the back of the studs when the badge is on, leave it for a few hours (night time best) and it should stay on but be able to come of again later, or failing that you can use a soldering iron to melt the edges of the tabs a bit, it will hold and you will probably be able to get it of but i doubt it will go back on again after
