That's rather odd, since cars registered between 1st August 1992 & 31st July 1995 are subject to a CAT emissions test as part of the MoT with the following requirements;
Idle (450rpm - 1500rpm)
CO <=0.5%
Fast Idle: (2500-3000rpm)
CO <=0.3%, HC <=200ppm, Lambda 0.97 - 1.03.
ALL UK spec Micras should be in the VOSA database. There are however some cases where people get away with non-cat tests, (usually March imports), the VOSA process flow diagram for an MOT test shows the following;
"Can you find an exact match in the analyser database or the In-Service Emissions book?"
If 'NO', the instruction is to Carry out a non CAT test CO <= 3.5% & HC <= 1200ppm.
You must have been lucky
How is your car described on your V5/V5C, model etc?
