Hi,
I'm having an issue with my hardwired dashcam (g1w); I connected it to the ACC fuse so it should turn on when the key is in ACC position and indeed it does, however if I stay in ACC for a while and then go IGNition, the camera gets confused and shut down as there is a moment there when the power is cut (radio goes off briefly as well).
Probably wiring it in the ignition fuse would solve this problem, but I'd like to keep the dashcam in ACC fuse, I feel it's worth capturing that footage as well, you know, when you are in the car with the engine stopped, just waiting for someone etc.
Has anyone hit this problem, how did you solve it?
