I have a DAB radio unit that I'm trying to fit in the Micra in combination with the Nissan CONNECT head unit.
(works by re-transmitting as FM, either wireless or with inline feed)
Ive worked out:
1) How to get to the Nissan CONNECT unit, Owl shaped dash central section pulls off, no screws. Supposedly easier from the bottom then the top, I found needed pulled from top edge first.
2) Ive located ground and ignition on the loom feeding the Nissan CONNECT lower of the 2 connectors, the main one.
Extreme left Black/white = ground
Extreme right = permanent live (did not use)
pin 7 blue top = ignition live
I've more or less decided where to put aerial:
I won't consider drilling a hole in the roof for another aerial/ or replacing the roof aerial with an FM/DAB combination aerial.
I could cut down the roof aerial but I still need an FM aerial for FM and navigation Traffic info.
First looked to see if I could fit it inside the rear spoiler on the DIG-S. Cant see any easy way to get the spoiler off or remove the high level light to put it inside.
In front of the radiator in the front bumper where I can mount aerial vertically and where there's no metal work in front of it seems best.
Problems I have:
If I put aerial in the front I have to get the aerial cable through the bulk head or put the DAB unit in the engine bay. If I put the dab unit in the engine bay I need to find a suitable +ve from the ignition.
Anyone either found a best place to pass a wire through the bulk head or a suitable place to get a live on the ignition from under the bonnet?
P.S. Yes I know the batteries under the bonnet but I want a suggestion on best ignition switched live that could be used. Preferably a not very important one or one that exists for additional equipment not usually fitted.
Regardless of this I would really want to go through the bulk head as I want to fit a cig-lighter/power outlet to the battery.
Suggestions for getting wire through bulkhead and where to take a live from in engine bay.
Ive worked out:
Problems I have:
