CMF_qwerty132
» CMF MemberHey Guys,
What is needed to swap from CVT to manual?
Does anyone have any hints etc. Is it easier to take the whole engine/box out to swap? The swap will be done at home so no hoist just car stands.
I have read here that the CVT ecu can run a manaul box. Is there any other wiring looms etc that need to be swapped over? Any problems with just using the manual drive shafts and CVs etc?
Are all the manual mount points, clutch cable brackets,holes in firewall, holes for the gear stick the same in an auto car?
Can any one give me a good reason not to do the swap?
I have a whole donor manual car for parts.
qwerty132
qwerty132
