CV joints!
that looks like the k10/preface 1.0k11 one to me, all the c/v,s have the same hub spline, but the k10/preface 1.0k11 have a smalller 19 spline bare shaft (the other shafts are 22 spline)
Thanks for the link. I ordered one. Always check the number of inner and outer splines before buying a cv joint and also if your car has ABS brakes. There are non ABS outer cv joints and ABS outer cv joints.
Well, it arrived in the post. It came with some ****ty alligator clips and I spent ages trying to pry open the teeth so they would catch properly. I will try to salvage the old clips and boot. The hub nut is 32mm and seems a little loose when I screw it up. Hopefully this cv joint will fit on properly.
Well, it arrived in the post. It came with some lame alligator clips and I spent ages trying to pry open the teeth so they would catch properly. I will try to salvage the old clips and boot. The hub nut is 32mm and seems a little loose when I screw it up. Hopefully this cv joint will fit on properly.
