CV joint for a k11 prefacelift 1.3 , does it fit a 1.0 too?
funky2nite
hi I'm in need to change my cv joint as when I full steer the wheels I hear a crackling noise coming from the right front wheel.
the mechanic said it's the CV joint needing replacement. I found at ebay a cv joint fitting a k11 micra 93-98 but for a 1.3 non abs...mine's a 1.0L non abs... from my ignorance I think it should fit.... should it guys?
also would it be best to change btoh cv joints? even though one is making the crackling noise..the mechanic thinks that it's not necessary to change both if only one is being funny... what';d you all say guys?
awaiting some sort of reply... as I need to buy it immediately to get it soon so the mchanic can fit it.. do you know where is cheapest I can get this damn cv joint.
cheers,
Ian - MALTA
