P
peu306xsi
Hi ppl..
I have a Nissan March DX, K10 model and i need to change the outer CV gator hub side on the passenger side. also i have to change the ball joint on the wishbone. I would like to know the correct procedure to change the CV gator mentioned above. Do i have to remove the drive shaft from the gearbox ? or can i insert the cv gator from the hub side ?? Do i need a special tool ? How can i open the cv gator to pass through the CV joint, on the hub side?
One final question, if i remove the drive shaft, would there be compications ? what happens on the gearbox side? because if i remove the shaft, i wil change both gators. If i remove the driveshaft from the gearbox side, to change the gator, do i have to dismantle the cv joint, so that i can insert both gator ?
Thanks a lot.. Please urgent ! :S
