CMF_chuckles
» CMF MemberHi guys,
up for sale is a custom made turbo manifold to suit a NON A/C K11 Micra. The manifold Itself made out of 1 1/4inch (32mmNB) manderal bent steam pipe and tig welded on a custom exhaust flange plate and T2 turbo flange
This was designed to fit the biggest sized turbo that could physicaly be top mounted with little modifcations but still keeping it the same height as the engine so its nice and neat under the bonnet.
there is only a couple of modifications needed to fit this setup:
- Swivel dip stick all the way to drivers side
- Notch out radiator support pannel or wastegate bracket. (notch would only need to be about a 20 - 20mm square)
Turbo is a brand new GT2871R which is oil and water fed, with a 60A/R front housing and a .64 rear.
also comes with base gasket, oil draing barb and anything els turbo related i can find to go with it
-also have angry eyed front bonnet doubled skinned and fully welded just needs skim of bog and prim and paint to the colour of your car,
-shaved front guards, fully welded and filled and sanded. Just needs priming and paint
-shaved hatch, has been filled sanded, just needs final prim and paint
-have super s front and rear bar with fog lights. both bars need work
- 2 near new front headlights, only been fitted to the car for about 2months
No longer have my project so no point in holding on to these parts.
would like to sell the lot as a package as they all work well together. chasing $1500 for the lot
Contact dayne - 0432 456 370
