Custom turbo manifold and GT2871R
CMF_chuckles
Hi guys,
up for sale is a custom made turbo manifold to suit a NON A/C K11 Micra. The manifold Itself made out of 1 1/4inch (32mmNB) manderal bent steam pipe and tig welded on a custom exhaust flange plate and T2 turbo flange
This was designed to fit the biggest sized turbo that could physicaly be top mounted with little modifcations but still keeping it the same height as the engine so its nice and neat under the bonnet.
there is only a couple of modifications needed to fit this setup:
- Swivel dip stick all the way to drivers side
- Notch out radiator support pannel or wastegate bracket. (notch would only need to be about a 20 - 20mm square)
Turbo is a brand new GT2871R which is oil and water fed, with a 60A/R front housing and a .64 rear.
also comes with base gasket, oil draing barb and anything els turbo related i can find to go with it
No longer have a micra and not needed anymore
Happy to assit with freight if need be, $1000ono
Contact Dayne - 0432456370 loctaed Brisbane
CMF_chuckles
Hey Pierce, iam in no rush to sell it so if it havent sold it by then, so if thats the case hopefuly talk to you soon.
Tyrie, its pretty much same spec as a garrett by just a chinese one like you get from 999 automotive. didnt want to spend the big bucks untill it was running to se response etc
