Custom interior lighting
Interesting idea.
I'm imagining the adjustable shift light circuit from an aftermarket tachometer feeding the coil of an SPDT relay, in turn driving RGB LEDs - with the terminal for blue on the relay's NC and the red on the NO.
Sent from my ONEPLUS A5010 using Micra Sports Club mobile app
SPDT stands for 'single pole, double throw'. Read a little on electronics and components - you're going to need it. I have no electronics training or experience so I'm not the one to teach you or anybody else; I've just done plenty of reading (online etc) over the years.
Good luck!
You might be able to make a potential divider with the rev counter wire as the input (not sure how that would effect the actual reading, maybe make a parallel wire to it in case?). If you use a variable resistor you can fine tune the circuit to get to the right revs.
Edit: cant's seem to upload the image or a link to the image, Google image search "potential divider variable" instead
The output could then trigger the switch between blue and red lights, with a transistor or relay
