I had a metal rattling when changing gear so had a look under the car today. Looks like the exhaust sheild rattling.
I then had a good look at the cross member and it is rotting at the front passenger corner just under a plastic cover. Not sure if it will fail an mot as not completely gone but it will need replacing eventually.
My question is, is it easier to change the complete front panel or just the cross member and is welding needed either way? Also can the welding be replaced with rivets or would that fail an mot?
If the whole front panel is replaced is it just bolted or as I say welding also? As it is cheaper to just get the cross member.
I am capable of doing the job myself apart from I have no welding gear though my father in law has welding gear for sure so could get it done if needed.
Simon.
Simon.
