My car seems to be running rough, I haven't been using it alot until about 3 weeks ago because of the CC, but I dusted the micra off, and since then it's been running rough (it's never been ''smooth'' on tickover since year dot)
I put some injector cleaner in tonight, I haven't driven it far since then. I don't know what else to try. I did clean the engine a while ago and that got the spark plug holes wet, and the tubes that go down into them are a tad rusty (surface) when that happened (early may) I soaked the water up and sprayed WD40 everywhere.
I'm going to try the following:-
I'd really, really appreciate some help here, as my parents have gone away in the CC and I'm stranded. It's worrying me big-time.
Thanks in advance. Nik
- Plugs
- Leads
- ECU Reset
- Have a look @ TB and see if joint is dry.
