crank shaft sensor
is it easy to remove the crank:: sensor on a k12 micra, as Ive read Kevlar may be on the fly wheel from production and this could be effecting its stability, and the fly wheel needs cleaning by use of a blow torch can it be removed and replaced without having to reset anything electrical.
lauro
yes, its just bolted into the gearbox lauro, you might be best to check the chain tensioner extension first tho
