Cracked thermostat housing
Hi all, recently had to change my thermostat as it was constantly open. The swap basically went fine until I over-tightened the last bolt causing the housing to crack and have coolant leak everywhere. Been trying to source a used one but no luck so far.
I don't suppose anyone here has one to sell or knows where I might be able to find one? Thanks!
Radikalman
The housing is separate from the engine head held by 3-4 bolts so u could pop down to scrappys and remove one from any k11
