Cracked Micra door handles
I'm sure your all aware of the common k11 fault of developing cracked handles (especially if they handles are not painted)!
Could anybody describe how to remove the external door handle for replacement?
Thanks!
Pop door card off, gently pull the plastic sheet away and then remove the 13 mm nut (for the window channel) on the edge of the door facing the rear. If I remember there's 2 10mm for the anti-smash guard then 2 10mm nuts and I took the rod out with the handle just be careful with paintwork. :)
took me literally 10/15 minutes and even the other half swapped one in about half an hour so a pretty easy job :)
Hope I've been a little bit clearer than mud haha
