Cr12de turbo
Hi, I was wondering if anyone has ever turbocharged a cr12de before? If so what turbo and kit should I go for as I want to have a go installing one. I have the 80 version 2005.
I have looked into this before and can cost 2000 just for fitting everything.then you may have to fit better bottom end to handle the boost... So can easy hit 3-4K
I was planing to fit one on my k12 but it will be a bad idea. The engine block,piston and other parts will handle the pressure. Or you have to adjust boost to 0.5 bar. don't pass over 0.5
Probably better and more cost effective to install an bigger engine. I’ve only heard of one k12 being turboed but the engine failed around 12000 miles Later. They installed an 2000cc engine afterwards and that gave it more pep.
i have looked into this a couple of months ago and it is expensive and doesn’t add too much power for the price. the best option is to swap the 1.6 from the sr and modify that engine
