Hi guys, if you missed my introduction thread I've recently saved a k reg 1.2 Micra from the crusher! :grinning:
Been using it as my sensible daily for a couple of months now just got a little issue I was wondering if any k10 experts may be able to shed some light on?
I spotted that it has electrical plugs all over the engine which I thought was highly unusual for a Micra, then I saw it had a cat and a lambda sensor - then some random pipe linking the exhaust manifold up to the inlet... The more I looked the more I realised it was a bit more advanced than the 1.0 Micra I had as a student!
Its been a bit 'hesitant' so after a search I found a thread about removing the EGR crap and the inlet to exhaust oxygen malarky so I've done that and to be fair it's much better! It's also got new plugs and leads and had 2 full tanks of super unleaded with redex fuel treatment as well as a whole can of carb cleaner.
When it's stone cold, a press of the throttle to the floor and then holding it halfway and it starts instantly and idles well. It's just it's still slightly hesitant when driving on partial/mid constant throttle. It also doesn't seem to rev with the characteristics of a carbed motor - it doesn't instantly drop down after a quick blip in neutral, it slowly drops as if it was fuel injected... Could this be linked to the slight 'hesitancy'? It's only got 44000 miles and to be fair starts and runs like a dream but I like to play till things are spot on and I'm wondering if the symptoms sound like any common problems you lot have come across? It did 65mpg on a recent long trip! And the heater is absolutely awesome! It's called William by the way...
Cheers guys (Y)
Cheers guys (Y)
