cisco
» CMF MemberMy mate in Japan is sending me over a couple of parts shortly.
One is a B-Crews k11 ABS Remove kit. So I can use it to join up my brake lines now that the ABS unit is removed.
The other thing is a B-Crews k11 engine damper. It bolts from the right hand strut tower onto the engine and stops the engine moving so much back and forth. Just dampens it and controls its movement. Gives smoother launches and release of power and makes your engine mounts last longer for high powered engines where there is much more wear and tear on them.
I'll post a pic when they arrive.
