Corsa Shocks
Ok, so I am gonna go the corsa rear shock route with 05 matiz rear springs to drop the rear, I know I need M10 bolts, but what length do I need? I got a box full of M10's but the longest is 70mm, this gonna be long enough? I am gonna do alto springs on the front so this should give me a 50mm drop, with 15" wheels it should sit nice.
you need the same length as the stock bolts AJ, 60ish ? and i had to fit some rubbers back onto the top perch look (else i got a "twang" on speedbumps) :)
that's cool, cheers frank, didn't want to get some new bolts when I got a box already, I will prob need to cut down the 70mm ones, but I will see how they fit, what rubbers did you use mate?
not sure what the rubbers were off tbh mate, here,s the later alto (left) they,re slightly barrel shaped, but the ends are bang-on dia
and the later matiz ones (middle) and a HKS front lowering spring
cheers Joe, just wanted to be sure, and I am sure I can find some rubbers to use from the rubbish scrappies round here lol
