Hi i was wonderind if corsa front struts will fit a k10 and if corsa hubs will fit the steering rack? I am thinking of fitting a c16xe (1.6) from a corsa into my micra.
Not worth it imo!
The struts will bolt into the k10 top mount if you drill the mount out from 10mm to 14mm. You could redrill the tapers if they don't match up but I bet there ain't much difference. The corsa track rod or rodend my be interchangeable also.
You will almost 100% defo need to cut and shut the shafts shorter so may as well cut and shut with micra shafts so you can keep micra hubs imo
Lastly I honestly think that to get the most from the micra chassis, you need the lightest engine and gearbox setup that meets your requirements.
A cg13de out of a k11 is fairly simple to fit and with some simple mods will make similar power to a standard c16. C16 is 106hp iirc and the cg13de is 80hp, but lighter and imo a more refined engine. My cg13de was making 98hp with 4 branch manifold and carbs (crap on fuel though) and was mated to a k11 cg10 small casing gearbox (short ratio
). Iam now switching back to injection and iam confident that with some swapping about of throttle bodies, injectors, fuel pressure and ecus, that I will be able to crack the 100hp mark. Cg10 pistons fit for higher compression (11.9:1 iirc) and reground cams ain't that pricey.
I personally think that with lighter, better revving engine and close ratio box, like above, is pretty much perfect setup for a k10.
Just my 2p worth
