[SOLD] Corsa coilover kit
Status
Not open for further replies.
B
blobbletec
Corsa coilover kit brand new unused.. i have modified the front top mounts so the fit the bearing better, they will come with a 10mm spacer and micra top mounts,
Rears consists of just a shock absorber that can be fitted with a little modification
Does have corsa springs and adjustable platforms but are not of any use for the micra
I believe there is a thread on how to do it in the diy section of this forum
I just dont have the time to fit to my micra and as it is for sale i dont see the point trying..!
I paid £160 for these off ebay a few weeks ago
Looking for £130 posted to uk mainland
£120 if you collect..
Hi. So are the fronts a straight swap, nothing else needs doing to them? and the rears can be modified to fit following the guide on here?
If so, i'm interested. But how much do you estimate they will lower the car by?
Matt
You need to elongate the lower mounting hole a few mm and swap the brake pipe bracket over, how low will it be..? dont know have i never fitted them to a micra..
Status
