Corsa b rear dampers question!!
I have two coils cut and i want to put the corsa b dampers on the back. If i do will the dampers be any lower than the original dampers? Or will it only depend on the spring? Had the matiz fronts from ebay but the seller sent me a lethal pair check photo lucky i spotted that because i was cleaning them up.
Springs are weight bearing shocks aren't :)
Depending on your springs free length if that is longer than that of the dampers open length then they'll limit height but that's all :)
What am I looking at/for ???
Report to trading standards, and VOSA for selling un-roadworthy parts. You may not get your money back, but you will cause them a whole lot of problems.
I've done it, and they closed the garage involved.
