I have just replaced my thermostat & Radiator.
My new thermostat has the bleed valve in it. Do I still need to do the bleed procedure below? Or is the valve in the thermostat, just to assist the procedure?
[To bleed the air you must take the top off the header tank and run the engine with the heater on full blast till the cooling fan cuts in, this should push all the air out of the system and then put the cap back on, thats the way I do it anyway! Must say though this would only need to be done if the coolant has just been replaced]
