D
Deleted member 31521
Hi i'm looking to find sizes for the compressions springs for the bolts at the catalytic converter as they were not present in the kit I recently bought if you know the size.
22.5mm X 18mm pack of 6
This is what I'm looking at. The maximum I can go to is around 18mm and if I go with 15mm or 16mm probably wont fit onto the bolt or maybe it would screw over the flange of the bolt unsure really.
hopefully they fit without being too wide on the bolt I'm totally unsure of the height needed but think half of the height may be fine these are just about half the height of the bolt part where the spring should be.
Just need to confirm now that the inner diameter is 18mm so it can reach the bottom of the bolt.
The bolt it fits on looks like this and after viewing the area I noticed they seemed to be missing compression springs. Previously got a kit excluding them as I didn't think they would be needed this is the best image i have of the bolt.
They are there to give the exhaust flexability.
If they are actually present by the look of the spacer that was used. They would be too short cause that bit is not ment to be on the bolt as far as im aware.
Just need these it seems
SPRING, EXHAUST PIPE (BOSAL 251-001)
This is the item that I think matches for the part. No image so lots of confusion in the long search.
Spring, exhaust pipe EMB018 EuroFlo
Genuine Top Quality Replacement New
Gonna be fun removing them by the looks of it
Compression spring (6 pack) DIY | eBay
Find many great new & used options and get the best deals for Compression spring (6 pack) DIY at the best online prices at eBay! Free delivery for many products.
www.ebay.co.uk
