Hello all you Micra men (and women)
Wondering if you could help please, I have a CGA3 1348 engine block fitted with forged pistons which are 72.145mm bore, which at TDC are flush with Deck height,
Bore Dia- 72.145mm
Head gasket compressed at 1.2 mm
Piston Stroke- 82.8mm
Head gasket bore Dia- 72.5mm
CC's within compression chamber- 23.5cc
Dome volume- 0
had approx. 22cc to start in the compession chamber, machined out either side the valves to now to get approx. 23.5cc, can I now machine the flat on the exhaust side to increase the CC to 24.5-25, or will this ruin the swirl and squish on the head gasket?
Looking on my figure 12.9:1 CR at the moment, Little High I'd say
Bore Dia- 72.145mm
Dome volume- 0
