compression in engine.
CMF_mipcar
Basically correct. However an overall lower reading (albeit even) in the cylinders will indicate things getting a little tired. I am interested to see how much (if any) compression has dropped in my 300+k engine.
A lower reading in a single cylinder from it's mates will point to problems in that particular cylinder, I'm just interested to see how much age is wearying my motor.
Mychael
CMF_Yom
MY Jap import motor did around 130psi (+/- 3psi) across the board on a dry hand crank test.
Wet would be a bit higher.
And don't stress if your compression is 'down' according to nissan specs. No gauge is 100% accurate.
