Been a while since I've been here haha... Couple updates of my findings, and a few more questions too! First, I figured out why my car was shuddering slightly whenever I shifted, it was lack of power from the engine... I got a new air filter,oil change and now I've added cold air intake, and it doesn't shudder anymore (yay!) However, now I'm having the problem of a fast idle when it's cold AND hot. No matter what the idle never drops below 2000 rpm... It's the biggest waste of gas ever and I'm getting annoyed with it frankly. So far I've taken the breather off the carb throat and played around with a bunch of linkages (cleaning and ensuring no binding is occurring) but it still won't do it. I only had to replace one vacuum line as it was cracked and disconnected. The rest look like they're in excellent condition. So far I've narrowed it down to 2 things. The first thing I'm guessing is that it's the spring that sits on the pivot of the accelerator arm. I believe it's lost it's consistency and so it's not pushing it all the way down to allow the proper choke. Well, actually I can almost guarantee that's the case since my car WILL idle at 800 rpm, however I need to physically push the accelerator arm all the way down to achieve that. The second thing is I'm guessing something is binding or something isn't properly set (and yes, the idle screw is set properly)..
I'm just teaching myself how a carb works right now, so unfortunately I don't know which parts are known to break down quicker than others. There's nothing wrong with the bimetal spring, and I've sprayed every possible part with carb cleaner (and I even took a toothbrush to it haha) and yet it still won't idle below 2000 rpm. So I'm guessing I have 2 options.. One is to try and make the spring that has been fatigued more taught and position it further down the arm to get better leverage to push it down. Or two, just replace the whole damn lump and get rid of the carb lol... It's getting about time to replace it anyways (~294000km on the clock, original engine)
Sorry for the long read, hope someone has some nice insights for me!
