CMF_Greo
» CMF MemberAll right, just after options/opinions on my current repair situation.
I have a 2nd hand set of G4 Coilovers (so age/kms done is unknown)and the drivers side rear strut has started leaking and knocking over bumps.
Do I:
A) Try to find a rebuild/seal kit for this set of (to my knowledge) discontinued make of coilover and take the rears some where to be rebuilt.
OR
B)Buy some stock Struts or KYB short stroke struts and ditch the dead coilover struts? Which in theory will maintain my current ride height as the rears are independent spring and strut system, and still function as the coilovers do. I do however foresee issues with the rear springs becoming uncaptive, a harsh ride due to pre-compression of the shocks and the shock prematurely wearing out due to constant compression under a lower ride height(more an issue for OEM Shocks).
Ideally I would just buy a full set of BCs and throw them in but my budget doesn't allow for this #unistudentlyf
Any recommendations on where to get the coilovers repaired (in BRISBANE), any suppliers of KYB (or similar) short stroke struts, or someone with a pair of standard rear shocks for cheap will be most welcome.
Thanks in advance guys.
Do I:
OR
