Clutch
Hi. My 2005 k12 1.4 has a clutch problem. From 1st to 5th no matter what revs she is fine. However in 5th with low revs, normally on an incline if you accelerate the revs climb with no increase in speed. Gear down to 4th and you get normal acceleration
Clutch is just about worn out, needs replacing...... Probably made worse by oil contamination, while the gearbox is out, replace the crankshaft oil seal behind the flywheel, and of course the hydraulic slave cylinder assembly....
