Clutch slipping 1.0 -1.3
Hi can any 1 advice me on a clutch problem I'm having I have a 1.3 k11 1996 I have a 1.0 flywheel fitted but every time I do the clutch up on the flywheel it pulls the centre of the pressure plate in and causes the clutch to keep slipping I have replaced the flywheel and have brought a new clutch kit but I still keep getting the same problem any help would be great as I have now had the box off 4 times! Thanks in advance
i had a 160mm exedy clutch that would,nt hold 1.3 power, the luk held about 90hp and i had to make a hybrid (160/180mm) clutch for the turbo
This might seem really stupid but are you putting the drive plate in the right way round? I work in a garage and have seen it done a few times
