Hi all!
Recently picked up a 2002 1.4L Micra - done a few little jobs on it already:
Coolant expansion tank had cracked, removed the toad immobiliser and changed the clutch cable as I thought that was my prob today!
The clutch peddle is still very stiff right at the bottom of the peddle, it goes into gear no problems, including reverse gear.
Clutch isn't slipping, as far as I can tell.
Cars only done 36k miles, from the paperwork given when I bought the car the clutch has already been changed at 12k miles in 2008 ?
Where the clutch cable hooks on the gearbox end is very stiff, when the cable was off I couldn't move by hand, and with the cable on it is squeaking very loudly. I've tried spraying it down with WD-40 with not much luck.
Anything I should be looking out for? Any help is appreciated, this is my first Micra (very different to the scoobys I'm used to) so not very knowledgeable on them!!
Many thanks
Nick
Many thanks
Nick
