Clutch pedal sticks halfway
After having had the clutch disc and plate replaced, the clutch pedal gets stuck halfway up and i have to bring it back up with my foot. Any idea what might be the cause of that?
Im no expert but i was having a similar problem and a couple of trustworthy people told me it could be the clutch cable is sticking in the lining. They said to take the cable out and spray it with wd40. could be a help if not its free anyways?
Try turning the cable wheel adjuster until gear changes happen at the lowest pedal point (1inch 2inch) then adjust more till your happy 'ish
