Clutch pedal height
CMF_M5
Hi Guys
Something I have been meaning to ask for a long time, I've noticed on my Micra (manual slx series 2)that the clutch pedal sits higher than the brake pedal. The car has never had a new clutch installed (148,000km and still going strong!) though i did replace the clutch cabble about a year ago. Is this higher clutch pedal a factory setting? or do you think someone has had a play with the pedal height at some stage maybe trying to create some more freeplay for the clutch.
Regards
Henry
CMF_makes
Hi Henry,
The clutch pedal in my car was also significantly higher than the brake pedal before I installed a new clutch recently....
With the new clutch installed and the correct cable/pedal adjustment the clutch pedal has now ended up at the same height as the brake pedal.
Yes, I think as the clutch wears out the pedal position is adjusted to keep the clutch operational within the proper limits.
CMF_M5
Thanks for that Makes, I appreciate your response to my question, I guess I will also end up with level pedals when new clutch time eventually comes around.....(hopefully not too soon!)
Regards
Henry
