the clutch cable bracing bracket where it hooks onto the clutch arm?
first unhook the cable end off the clutch arm,
then pull back the consatina rubber inner cable cover away from the outer cable to expose the inner cable,
then pull the outer cable backwards off the support bracket,
then feed the exposed inner cable sideways out the narrow bracket slot
